Shelly H&T wifi, app interface question
  • Hello,
    I have a question about the interface of the shelly app.
    I made 2 seperate rooms in the app with each one HT sensor. In the dashboard it shows both rooms below eachother with a picture.
    But the above room also shows the sensor readings in the dashboard picture, but the below room does not show the sensor readings from the dashboard overview.
    For that i first have to open the below room where i find the readings.
    For a quick overview it would be nice that in the dashboard overview each room will emidiately show the sensor readings.
    Also see my screenshot so you know what i mean.
    Is there a way to fix or update this?
    In the room in which the H&T is located in the APP - tap the pencil symbol at the top right - tap the yellow pencil symbol from the H&T - edit the device - checkmark for "Set this sensor as the standard for the room".
