Interfacing to existing roller shutter controller
  • If I connect the Shelly 2,5 switch inputs to my existing roller shutter controller will it work ?
    Ie drive the Shelly from the existing controller.
    The input would not be momentary but would be on for duration of movement up or down.
    Ie is the switch input edge triggered ?
    Using 240v
    Interfacing to existing controller allows in room wall buttons and hand held remote to still function.
  • Hi Stephan
    Unfortunately I have no data for that controller
    It simply switches the 240v to the motor in the same way that the Shelly does
    It could be wired into the 2 switch inputs on the Shelly to activate it and let the shellys relays operate the motor
    The problem I foresee is that the Shelly may require a momentary input whereas this would be
    In the switch state for the period of time that the roller shutter would normally operate
    Would this cause the Shelly to not operate correctly ?
    No, the shelly works with a switch properly.
    I think, there is no problem. ;)
