Standalone switch for Home assistant
  • Hi!
    I have a Shelly 2.5 that I want to install on a 2 pulse button wall switch.
    When I press a button, I just want the Shelly to send a trigger to Home Assistant, and there I will decide what to do.
    Just that! So no other lamps to connect to directly.
    On the wall I have Neutral and Phase for the Shelly.
    Is this possible? How would the circuit look like?
    Thanks in advance!
  • Hi,
    you will find the wiring in section "Lexikon" part "connection diagram". For your project you don't have to connect the load.
    And in part "Http-Requests" of the "Lexikon" you will find some pattern for the message you will create.
    Good luck
    Viele Grüße,
    Wolfgang
  • Hi Eulhofer,
    Thanks for your reply!
    The diagrams I see all have lamps, shutters or some other kind of device. I just want the switches and the Shelly.
    You say I don't have to connect the load, which terminals you mean exactly?
    Thanks!
    • Hilfreichste Antwort
    Hi,
    exactly what you wrote: No load as lamps, shutter or other kind of device...
    Just connect the supply and the switch... thats it.
    Viele Grüße,
    Wolfgang
  • Ok, clear, so it will be something like this then:
    Will be trying this soon. Thanks for your help Eulhofer!
