Ubiquiti U6-Lite (Wifi 6) Connection Problem
  • Hello,
    Someone with problems connecting with the Ubiquiti U6-Lite (WIFI 6)?, I only have the 2.4Ghz range active, already set fixed ip's and tried it via DHCP and I can't connect.
    Tested with Shelly 2.5 and Dimmer 2, EM...
    Shelly 2.5 "Current version: 20210429-100559/v1.10.4-g3f94cd7"
    Shelly Dim2 "Current version: 20210429-102101/v1.10.4-g3f94cd7"
    U6-Lite Version 5.43.23
    After switching the wifi network to "ubiquiti" seems that Shelly returns to the default settings, I turn on his wi-fi network and access with the source IP to configure again.
    With connection to the operator's router, it works at 100%.
    Any suggestion?
  • Hello,
    Yes I've read many of them and I can't resolve the situation...
    I've gone around Shelly's and Unifi's settings and I can't find a way to work.
